AVR
작성일17-11-15 16:25
조회3,819회
//1. baud rate를 선택
#define USART_BAUDRATE 9600
//2.시스템 클록과 원하는 baud rate를 이용하여 UBRR 값을 계산한다.
#define UBRR_VALUE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
#include <avr/io.h>
#include <avr/interrupt.h>
void usartInit()
//3. UBRR0은 16비트 레지스터이기 때문에 8비트씩 나누어서 넣어야 한다.
UBRR0H = (uint8_t)(UBRR_VALUE>>8);
UBRR0L = (uint8_t) UBRR_VALUE;
//4. USART 설정
UCSR0C |= (1<<UCSZ00)|(1<<UCSZ01); //Charecter size : 8비트
UCSR0C &= ~(1<<USBS0); //stop bit : 1비트
UCSR0C &= ~((1<<UPM01)|(1<<UPM00)); // no parity mode
//5. 송수신을 가능하게 한다.
UCSR0B=(1<<RXEN0)|(1<<TXEN0);
void transmitByte(uint8_t data) {
//이전 전송이 끝나기를 기다림
while(!(UCSR0A&(1<<UDRE0))){};
UDR0 = data; /* send data */
uint8_t receiveByte(void) {
// 수신 되기를 기다림
while(!(UCSR0A&(1<<RXC0))){};
return UDR0; /* return register value */
void printString(volatile unsigned char str[]) {
uint8_t i = 0;
while (str[i]!='\0') {
transmitByte(str[i]);
i++;
void readString(char str[], uint8_t maxLength) {
char response;
uint8_t i;
i = 0;
while (i < (maxLength - 1)) { /* prevent over-runs */
response = receiveByte();
transmitByte(response); /* echo */
if (response == '\r') { /* enter marks the end */
break;
else {
str[i] = response; /* add in a letter */
i++;
str[i] = 0; /* terminal NULL character */
void init_SPI( ) {
DDRB &= ~((1<<PB1)|(1<<PB2)|(1<<PB0)); // SCK, MOSI, SS --> inputs
DDRB |= (1<<PB3); // MISO --> output
//slave mode
SPCR &= ~(1<<MSTR);
//16000KHz / 16
SPCR |= (1<<SPR0);
//enable SPI
SPCR |= ((1<<SPE)|(1<<SPIE));
unsigned char SPI_write(unsigned char cData) {
SPDR = cData;
while ( !(SPSR & (1<<SPIF))) ;
return SPDR;
unsigned char SPI_read( void ) {
SPDR = 0x0;
return SPDR;
volatile unsigned char str[100];
ISR(SPI_STC_vect)
static uint8_t idx=0;
unsigned char ch = SPDR;
if ( ch == '\0' )
str[idx]='\0';
printString(str);
idx=0;
else {
str[idx]=ch;
idx++;
int main (void)
init_SPI();
usartInit();
sei();
while(1)
