【라즈베리파이】 wiringPi Python : Character LCD 2*16 문자출력
작성자 임베디드코리아 작성일26-02-20 00:19 조회1,723회 댓글0건
■ Character LCD 2*16
Pin 1 (GND), 3 (Contrast), 5 (RW) and 16 (LED -) ( should be tied to ground.
Pin 2 should be tied to 5V. Pin 15 should have a resistor inline to 5V to protect the backlight.
Pin 7-10 are unconnected
Pin 11-14 are connected to GPIO pins on the Pi
--->>>  charLCD.py  <<<--------------------------------------------
#!/usr/bin/python
#    ___  ___  _ ____
#  / _ \/ _ \(_) __/__  __ __
#  / , _/ ___/ /\ \/ _ \/ // /
# /_/|_/_/  /_/___/ .__/\_, /
#                /_/  /___/
#  lcd_16x2.py
#  16x2 LCD Test Script
# Author : Matt Hawkins
# Date  : 06/04/2015
# https://www.raspberrypi-spy.co.uk/
# The wiring for the LCD is as follows:
# 1 : GND
# 2 : 5V
# 3 : Contrast (0-5V)*
# 4 : RS (Register Select)
# 5 : R/W (Read Write)      - GROUND THIS PIN
# 6 : Enable or Strobe
# 7 : Data Bit 0            - NOT USED
# 8 : Data Bit 1            - NOT USED
# 9 : Data Bit 2            - NOT USED
# 10: Data Bit 3            - NOT USED
# 11: Data Bit 4
# 12: Data Bit 5
# 13: Data Bit 6
# 14: Data Bit 7
# 15: LCD Backlight +5V**
# 16: LCD Backlight GND
#import
# Define GPIO to LCD mapping
LCD_RS = 7
LCD_E  = 8
LCD_D4 = 25
LCD_D5 = 24
LCD_D6 = 23
LCD_D7 = 18
# Define some device constants
LCD_WIDTH = 16    # Maximum characters per line
LCD_CHR = True
LCD_CMD = False
LCD_LINE_1 = 0x80 # LCD RAM address for the 1st line
LCD_LINE_2 = 0xC0 # LCD RAM address for the 2nd line
# Timing constants
E_PULSE = 0.0005
E_DELAY = 0.0005
def main():
  # Main program block
  GPIO.setwarnings(False)
  GPIO.setmode(GPIO.BCM)      # Use BCM GPIO numbers
  GPIO.setup(LCD_E, GPIO.OUT)  # E
  GPIO.setup(LCD_RS, GPIO.OUT) # RS
  GPIO.setup(LCD_D4, GPIO.OUT) # DB4
  GPIO.setup(LCD_D5, GPIO.OUT) # DB5
  GPIO.setup(LCD_D6, GPIO.OUT) # DB6
  GPIO.setup(LCD_D7, GPIO.OUT) # DB7
  # Initialise display
  lcd_init()
    # Send some test
    lcd_string("Rasbperry Pi",LCD_LINE_1)
    lcd_string("16x2 LCD Test",LCD_LINE_2)
    time.sleep(3) # 3 second delay
    # Send some text
    lcd_string("1234567890123456",LCD_LINE_1)
    lcd_string("abcdefghijklmnop",LCD_LINE_2)
    # Send some text
    lcd_string("RaspberryPi-spy",LCD_LINE_1)
    lcd_string(".co.uk",LCD_LINE_2)
    time.sleep(3)
    # Send some text
    lcd_string("Follow me on",LCD_LINE_1)
    lcd_string("Twitter @RPiSpy",LCD_LINE_2)
    time.sleep(3)
def lcd_init():
  lcd_byte(0x33,LCD_CMD) # 110011 Initialise
  lcd_byte(0x32,LCD_CMD) # 110010 Initialise
  lcd_byte(0x06,LCD_CMD) # 000110 Cursor move direction
  lcd_byte(0x0C,LCD_CMD) # 001100 Display On,Cursor Off, Blink Off
  lcd_byte(0x28,LCD_CMD) # 101000 Data length, number of lines, font size
  lcd_byte(0x01,LCD_CMD) # 000001 Clear display
  time.sleep(E_DELAY)
def lcd_byte(bits, mode):
  # Send byte to data pins
  # bits = data
  # mode = True  for character
  #        False for command
  GPIO.output(LCD_RS, mode) # RS
  # High bits
  GPIO.output(LCD_D4, False)
  GPIO.output(LCD_D5, False)
  GPIO.output(LCD_D6, False)
  GPIO.output(LCD_D7, False)
  if bits&0x10==0x10:
    GPIO.output(LCD_D4, True)
  if bits&0x20==0x20:
    GPIO.output(LCD_D5, True)
  if bits&0x40==0x40:
    GPIO.output(LCD_D6, True)
  if bits&0x80==0x80:
    GPIO.output(LCD_D7, True)
  # Toggle 'Enable' pin
  lcd_toggle_enable()
  # Low bits
  if bits&0x01==0x01:
  if bits&0x02==0x02:
  if bits&0x04==0x04:
  if bits&0x08==0x08:
  lcd_toggle_enable()
def lcd_toggle_enable():
  # Toggle enable
  time.sleep(E_DELAY)
  GPIO.output(LCD_E, True)
  time.sleep(E_PULSE)
  GPIO.output(LCD_E, False)
  time.sleep(E_DELAY)
def lcd_string(message,line):
  # Send string to display
  message = message.ljust(LCD_WIDTH," ")
  lcd_byte(line, LCD_CMD)
  for i in range(LCD_WIDTH):
    lcd_byte(ord(message[i]),LCD_CHR)
if __name__ == '__main__':
    main()
    pass
  finally:
    lcd_byte(0x01, LCD_CMD)
    lcd_string("Goodbye!",LCD_LINE_1)
    GPIO.cleanup()
