Kotlin 대화상자(Dialog) : DatePicker, TimePickerDialog)
작성자 임베디드코리아 작성일23-09-25 01:36 조회7,286회 댓글0건
        android:id="@+id/btn_load_calendar"
        android:text="날짜 선택"/>
        android:id="@+id/text_selected_date"
        android:gravity="center"
        android:textSize="20sp"
        android:layout_weight="1"/>
        android:id="@+id/btn_load_timer"
        android:text="시간 선택"/>
        android:id="@+id/text_selected_time"
        var BTN_load_calendar: Button = findViewById(R.id.btn_load_calendar)
        var BTN_load_timer: Button = findViewById(R.id.btn_load_timer)
        var TEXT_selected_date: TextView = findViewById(R.id.text_selected_date)
        var TEXT_selected_time: TextView = findViewById(R.id.text_selected_time)
        val cal = Calendar.getInstance()
        // 달력 로드
        BTN_load_calendar.setOnClickListener {
            DatePickerDialog(this, DatePickerDialog.OnDateSetListener { datePicker, y, m, d ->
                TEXT_selected_date.text = "$y/${m+1}/$d"
            }, cal.get(Calendar.YEAR), cal.get(Calendar.MONTH), cal.get(Calendar.DAY_OF_MONTH)).show()
        // 타이머 로드
        BTN_load_timer.setOnClickListener {
            TimePickerDialog(this, TimePickerDialog.OnTimeSetListener { timePicker, h, m ->
                TEXT_selected_time.text = "$h:$m"
            }, cal.get(Calendar.HOUR), cal.get(Calendar.MINUTE), true ).show()
