Kotlin 고급 위젯 - 날짜와 시간 관련 위젯 : 크로노미터(Chronometer)
작성자 임베디드코리아 작성일23-09-24 00:03 조회6,992회 댓글0건
    <LinearLayout
        <Chronometer
            android:id="@+id/exChronometer"
            android:format="시간 측정 : %s"
            android:gravity="center"
            android:textSize="30dp" />
            android:id="@+id/startBT"
            android:text="START"
            android:layout_marginLeft="20dp"
            android:id="@+id/stopBT"
            android:text="STOP"
            android:id="@+id/restartBT"
            android:text="RESTART"
            android:id="@+id/setBT"
            android:text="SET FORMAT"
            android:id="@+id/clearBT"
            android:text="CLEAR FORMAT"
    private lateinit var simpleChronometer: Chronometer
    private lateinit var start: Button
    private lateinit var stop: Button
    private lateinit var restart: Button
    private lateinit var setFormat: Button
    private lateinit var clearFormat: Button
    var pauseTime=0L
        simpleChronometer = findViewById(R.id.exChronometer)
        start = findViewById(R.id.startBT)
        stop = findViewById(R.id.stopBT)
        restart= findViewById(R.id.restartBT)
        setFormat = findViewById(R.id.setBT)
        clearFormat = findViewById(R.id.clearBT)
        start.setOnClickListener  {
            simpleChronometer.start()
        stop.setOnClickListener  {
            pauseTime = simpleChronometer.base - SystemClock.elapsedRealtime()
            simpleChronometer.stop()
        restart.setOnClickListener  {
            simpleChronometer.base = SystemClock.elapsedRealtime()+pauseTime
        setFormat.setOnClickListener  {
            simpleChronometer.setFormat("새로운 형식 : %s")
        clearFormat.setOnClickListener  {
            simpleChronometer.setFormat("")
