Kotlin 구구단
작성자 임베디드코리아 작성일23-09-18 00:36 조회6,729회 댓글0건
Kotlin  구구단
    private lateinit var DanET: EditText
    private lateinit var ExButton: Button
    private lateinit var ResultTV: TextView
    private var result:Int=0
    private var danNum:Int=0
        DanET= findViewById(R.id.Dan_ET)
        ExButton = findViewById(R.id.EX_BT)
        ResultTV = findViewById(R.id.result_TV)
        DanET.setOnClickListener  {
            DanET.setText(null)
        ExButton.setOnClickListener  {
            var danSTR: String = DanET.text.toString()
            danNum = danSTR.toInt()
            ResultTV.text=""
            for (cnt in 1..9){
                result=danNum*cnt
                ResultTV.append("$danNum * $cnt = $result  \n")
        android:id="@+id/Dan_ET"
        android:ems="10"
        android:inputType="text"
        android:background="#C1BDBD"
        android:layout_gravity="center" />
        android:id="@+id/EX_BT"
        android:text="실 행"
        android:id="@+id/result_TV"
        android:layout_width="300dp"
        android:background="#8CBDA5"
        android:textSize="20sp"
        android:textStyle="bold"
