Kotlin 고급 위젯 - 날짜와 시간 관련 위젯 : 날짜 / 시간 예약 앱 만들기
작성자 임베디드코리아 작성일23-09-24 01:17 조회7,581회 댓글0건
    android:baselineAligned="false"
    <LinearLayout
        <Chronometer
            android:id="@+id/chronometer1"
            android:format="예약에 걸린 시간 %s"
            android:gravity="center"
            android:textSize="20dp"
            android:id="@+id/btnStart"
            android:text="예약 시작"/>
    <RadioGroup
        android:layout_height="wrap_content">
        <RadioButton
            android:id="@+id/rdoCal"
            android:text="날짜 설정(캘린더뷰)"/>
        <RadioButton
            android:id="@+id/rdoTime"
            android:text="시간 설정"/>
    </RadioGroup>
    <LinearLayout
        android:layout_height="0dp"
        android:layout_weight="1">
        <FrameLayout
            android:gravity="center">
            <CalendarView
                android:id="@+id/calendarView1"
                android:showWeekNumber="false" />
            <TimePicker
                android:id="@+id/timePicker1"
                android:layout_height="match_parent" />
        </FrameLayout>
    <LinearLayout
        android:background="#cccccc">
            android:id="@+id/btnEnd"
            android:text="예약완료"/>
            android:id="@+id/tvYear"
            android:text="0000"/>
            android:text="년"/>
            android:id="@+id/tvMonth"
            android:text="00"/>
            android:text="월"/>
            android:id="@+id/tvDay"
            android:text="00"/>
            android:text="일"/>
            android:id="@+id/tvHour"
            android:text="00"/>
            android:text="시"/>
            android:id="@+id/tvMinute"
            android:text="00"/>
            android:text="분 예약됨"/>
    private lateinit var chrono: Chronometer
    private lateinit var btnStart: Button
    private lateinit var btnEnd: Button
    private lateinit var rdoCal: RadioButton
    private lateinit var rdoTime: RadioButton
    private lateinit var calView: CalendarView
    private lateinit var tPicker: TimePicker
    private lateinit var tvYear: TextView
    private lateinit var tvMonth: TextView
    private lateinit var tvDay: TextView
    private lateinit var tvHour: TextView
    private lateinit var tvMinute: TextView
    var selectYear: Int=0
    var selectMonth: Int=0
    var selectDay: Int=0
        setTitle("시간예약");
        btnStart = findViewById(R.id.btnStart)
        btnEnd = findViewById(R.id.btnEnd)
        chrono= findViewById(R.id.chronometer1)
        rdoCal = findViewById(R.id.rdoCal)
        rdoTime = findViewById(R.id.rdoTime)
        tvYear = findViewById(R.id.tvYear)
        tvMonth = findViewById(R.id.tvMonth)
        tvDay = findViewById(R.id.tvDay)
        tvHour = findViewById(R.id.tvHour)
        tvMinute = findViewById(R.id.tvMinute)
        calView = findViewById(R.id.calendarView1)
        tPicker = findViewById(R.id.timePicker1)
        //라디오버튼 클릭 시 캘린더뷰와 타임피커 중 하나씩만 보이게 클릭 이벤트 리스너
        rdoCal.setOnClickListener {
            tPicker.setVisibility(View.INVISIBLE)
            calView.setVisibility(View.VISIBLE)
        rdoTime.setOnClickListener {
            tPicker.setVisibility(View.VISIBLE)
            calView.setVisibility(View.INVISIBLE)
        btnStart.setOnClickListener {
            chrono.setBase(SystemClock.elapsedRealtime())
            chrono.start();
            chrono.setTextColor(Color.RED);
        btnEnd.setOnClickListener {
            chrono.stop();
            chrono.setTextColor(Color.BLUE);
            //예약완료 클릭 시 그 내용이 텍스트뷰에 채워지게 함
            tvYear.text = selectYear.toString()
            tvMonth.text = selectMonth.toString()
            tvDay.text = selectDay .toString()
            tvHour.text = tPicker.currentHour.toString()
            tvMinute.text = tPicker.currentMinute.toString()
        calView.setOnDateChangeListener { view, year, month, dayOfMonth ->
            selectYear = year
            selectMonth = month+1
            selectDay = dayOfMonth
