Kotlin 메뉴(Menu) : 컨텍스트 메뉴(ContextMenu)- 배경색 변경
작성자 임베디드코리아 작성일23-11-16 11:50 조회5,387회 댓글0건
- 배경색 변경 및 버튼 변경 앱 만들기
    android:id="@+id/baseLayout"
    android:gravity="center"
        android:id="@+id/button1"
        android:text="배경색 변경" />
        android:id="@+id/button2"
        android:text="버튼 변경" />
    lateinit var button1 : Button
    lateinit var button2 : Button
    lateinit var baseLayout : LinearLayout
        title = "배경색 바꾸기(Kotlin 코드)"
        baseLayout = findViewById<LinearLayout>(R.id.baseLayout) as LinearLayout
        button1 = findViewById<View>(R.id.button1) as Button
        registerForContextMenu(button1)
        button2 = findViewById<View>(R.id.button2) as Button
        registerForContextMenu(button2)
    override fun onCreateContextMenu(menu: ContextMenu, v: View,
                                    menuInfo: ContextMenu.ContextMenuInfo?) {
        super.onCreateContextMenu(menu, v, menuInfo)
        if (v === button1) {
            menu.setHeaderTitle("배경색 변경")
            menu.add(0, 1, 0, "배경색 (빨강)")
            menu.add(0, 2, 0, "배경색 (초록)")
            menu.add(0, 3, 0, "배경색 (파랑)")
        if (v === button2) {
            menu.add(0, 4, 0, "버튼 45도 회전")
            menu.add(0, 5, 0, "버튼 2배 확대")
    override fun onContextItemSelected(item: MenuItem) : Boolean {
        when (item.itemId) {
            1 -> {
                baseLayout.setBackgroundColor(Color.RED)
                return true
            2 -> {
                baseLayout.setBackgroundColor(Color.GREEN)
                return true
            3 -> {
                baseLayout.setBackgroundColor(Color.BLUE)
                return true
            4 -> {
                button2.rotation = 45f
                return true
            5 -> {
                button2.scaleX = 2f
                return true
        return false
*****      themes.xml  **********
    <style name="Base.Theme.ContextMenuColor" parent="Theme.MaterialComponents.DayNight.DarkActionBar">
        <item name="colorPrimary">#E91E63</item>
        <item name="colorPrimaryDark">#3F51B5</item>
    <style name="Theme.ContextMenuColor" parent="Base.Theme.ContextMenuColor" />
