Kotlin 메뉴(Menu) : 옵션 메뉴(option menu)-배경색 변경 앱
작성일 23-11-16 11:46
조회5,782회
배경색 변경 앱 만들기
android:id="@+id/baseLayout"
android:gravity="center_horizontal"
android:text="오른쪽 위 메뉴 버튼을 누르세요"
android:textSize="20dp" />
android:id="@+id/button1"
android:text="이건 버튼" />
lateinit var baseLayout : LinearLayout
lateinit var button1 : Button
title = "배경색 바꾸기"
baseLayout = findViewById<LinearLayout>(R.id.baseLayout)
button1 = findViewById<Button>(R.id.button1)
override fun onCreateOptionsMenu(menu: Menu?) : Boolean {
var mInflater = menuInflater
mInflater.inflate(R.menu.menu1, menu)
return true
override fun onOptionsItemSelected(item: MenuItem) : Boolean {
when (item.itemId) {
R.id.itemRed -> {
baseLayout.setBackgroundColor(Color.RED)
return true
R.id.itemGreen -> {
baseLayout.setBackgroundColor(Color.GREEN)
return true
R.id.itemBlue -> {
baseLayout.setBackgroundColor(Color.BLUE)
return true
R.id.subRotate -> {
button1.rotation = 45f
return true
R.id.subSize -> {
button1.scaleX = 2f
return true
return false
***** menu1.xml * ******
menu 폴더 만들기 --> New ---> Android Resource Directory
menu.xml 만들기 --> New ---> Menu Resource File
<menu xmlns:android="http://schemas.android.com/apk/res/android">
<item
android:id="@+id/itemRed"
android:title="배경색 (빨강)">
</item>
<item
android:id="@+id/itemGreen"
android:title="배경색(초록)">
</item>
<item
android:id="@+id/itemBlue"
android:title="배경색(파랑)">
</item>
<item android:title="버튼 변경 >> ">
<menu>
<item
android:id="@+id/subRotate"
android:title="버튼 45도 회전"/>
<item
android:id="@+id/subSize"
android:title="버튼 2배 확대"/>
</menu>
</item>
</menu>
***** themes.xml **********
<style name="Base.Theme.MenuOptionmenu" parent="Theme.MaterialComponents.DayNight.DarkActionBar">
<item name="colorPrimary">#7CB342</item>
<style name="Theme.MenuOptionmenu" parent="Base.Theme.MenuOptionmenu" />
