작성일23-11-16 11:49
조회5,803회
Kotlin 메뉴(Menu) : 그림 변경과 회전 하기
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:id="@+id/baseLayout"
<ImageView
android:id="@+id/imageView1"
android:layout_centerHorizontal="true"
android:layout_centerVertical="true"
android:src="@drawable/jeju2" />
android:id="@+id/edtAngle"
android:layout_alignParentTop="true"
android:layout_toRightOf="@+id/textView1"
android:text="0" >
</EditText>
android:id="@+id/textView1"
android:layout_alignBottom="@+id/edtAngle"
android:layout_alignParentLeft="true"
android:text=" Է "
android:textSize="20dp" />
</RelativeLayout>
lateinit var edtAngle : EditText
lateinit var imageView1 : ImageView
title = "제주도 풍경"
edtAngle = findViewById<EditText>(R.id.edtAngle)
imageView1 = findViewById<ImageView>(R.id.imageView1)
override fun onCreateOptionsMenu(menu: Menu): Boolean {
val mInflater = menuInflater
mInflater.inflate(R.menu.menu1, menu)
return true
override fun onOptionsItemSelected(item: MenuItem) : Boolean {
when (item.itemId) {
R.id.itemRotate -> {
imageView1.rotation = java.lang.Float.parseFloat(edtAngle.text.toString())
return true
R.id.item1 -> {
imageView1.setImageResource(R.drawable.jeju2)
return true
R.id.item2 -> {
imageView1.setImageResource(R.drawable.jeju14)
return true
R.id.item3 -> {
imageView1.setImageResource(R.drawable.jeju6)
return true
return false
***** menu1.xml * ******
menu 폴더 만들기 --> New ---> Android Resource Directory
menu.xml 만들기 --> New ---> Menu Resource File
<menu xmlns:android="http://schemas.android.com/apk/res/android">
<item
android:id="@+id/itemRotate"
android:title="그림 회전">
</item>
<group android:checkableBehavior="single" >
<item
android:id="@+id/item1"
android:checked="true"
android:title="한라산">
</item>
<item
android:id="@+id/item2"
android:title="추자도">
</item>
<item
android:id="@+id/item3"
android:title="범섬">
</item>
</group>
</menu>
***** themes.xml **********
<style name="Base.Theme.MenuOptionmenu" parent="Theme.MaterialComponents.DayNight.DarkActionBar">
<item name="colorPrimary">#8D8F9C</item>
<item name="colorPrimaryDark">#CDDC39</item>
<style name="Theme.MenuOptionmenu" parent="Base.Theme.MenuOptionmenu" />
