Kotlin 파일처리 : 앱(App) Cache Write ,Read
작성자 임베디드코리아 작성일23-10-03 23:04 조회6,777회 댓글0건
        android:layout_height="55dp"
        android:inputType="textPersonName"
        android:ems="10"
        android:id="@+id/editText"
        app:layout_constraintHorizontal_bias="0.504"
        app:layout_constraintVertical_bias="0.2"/>
        android:text="Cache Write"
        android:layout_width="148dp"
        android:layout_height="81dp"
        android:id="@+id/write"
        app:layout_constraintVertical_bias="0.361"
        app:layout_constraintHorizontal_bias="0.1"/>
        android:text="Cache Read"
        android:id="@+id/read"
        app:layout_constraintHorizontal_bias="0.8"/>
        android:id="@+id/clear"
        android:layout_width="396dp"
        android:layout_height="78dp"
        android:text="EditText Clear"
        app:layout_constraintBottom_toBottomOf="@+id/DataTV"
        app:layout_constraintVertical_bias="0.8"
        tools:layout_editor_absoluteX="1dp" />
        android:id="@+id/DataTV"
        android:layout_height="50dp"
        android:background="#E5FB15"
        app:layout_constraintTop_toBottomOf="@+id/clear"
        app:layout_constraintVertical_bias="0.15"
        tools:layout_editor_absoluteX="0dp" />
class MainActivity : AppCompatActivity(), View.OnClickListener {
        val read =  findViewById<Button>(R.id.read)
        val write =  findViewById<Button>(R.id.write)
        val clear =  findViewById<Button>(R.id.clear)
        read.setOnClickListener(this)
        write.setOnClickListener(this)
        clear.setOnClickListener(this)
    override fun onClick(view: View?) {
        val edit = findViewById<EditText>(R.id.editText)
        if(view?.id==R.id.read){
            loadCache()
        else if(view?.id==R.id.write){
            var data:String = edit.text.toString()
          // data="ppppppp"
            val file = File(cacheDir, "myCache")
            val outputStream = FileOutputStream(file)
            outputStream.write(data.toByteArray())
            outputStream.close()
            Toast.makeText(applicationContext, "data.toByteArray() saved", Toast.LENGTH_LONG).show()
        else if(view?.id==R.id.clear){
            edit.setText("")
            //clear 버튼을 누를시 입력창을 지운다.
    private fun saveCache(data: String) {
        try {
        } catch (e: IOException) {
            e.printStackTrace()
    private fun loadCache(){
        try {
            if (!file.exists()) file.createNewFile()
            val inputStream = FileInputStream(file)
            val s = Scanner(inputStream)
            var text:String = ""
            while (s.hasNext()) {
                text += s.nextLine()
            inputStream.close()
            Toast.makeText(applicationContext, "FileInputStream", Toast.LENGTH_LONG).show()
            var dataTV: TextView = findViewById(R.id.DataTV)
            dataTV.text = text
            e.printStackTrace()
