Kotlin 대화상자(Dialog) : 날짜추출 대화상자(DatePickerDialog)
작성일 23-09-25 01:25
조회6,545회
android:id="@+id/start_text"
style="bold"
android:layout_width="60dp"
android:gravity="center"
android:text="시 작"
android:textSize="20dp"
app:layout_constraintEnd_toStartOf="@+id/start_date_text"
app:layout_constraintVertical_bias="0.147" />
android:id="@+id/start_date_text"
android:layout_width="200dp"
android:layout_height="40dp"
android:layout_marginStart="60dp"
android:gravity="center_vertical"
android:paddingHorizontal="5dp"
app:layout_constraintStart_toEndOf="@+id/start_text"
app:layout_constraintVertical_bias="0.137" />
<ImageView
android:id="@+id/start_date_btn"
android:layout_width="349dp"
android:layout_height="414dp"
tools:layout_editor_absoluteX="16dp"
tools:layout_editor_absoluteY="236dp" />
//Calendar
private var calendar = Calendar.getInstance()
private var year = calendar.get(Calendar.YEAR)
private var month = calendar.get(Calendar.MONTH)
private var day = calendar.get(Calendar.DAY_OF_MONTH)
var start_date_BTN: ImageView = findViewById(R.id.start_date_btn)
var start_date_TEXT: TextView = findViewById(R.id.start_date_text)
start_date_BTN.setOnClickListener {
val datePickerDialog = DatePickerDialog(this, { _, year, month, day ->
start_date_TEXT.text =
year.toString() + "/" + (month + 1).toString() + "/" + day.toString()
}, year, month, day)
datePickerDialog.show()
