Kotlin 파일처리 : 권한 설정하기
작성자 임베디드코리아 작성일23-10-06 22:17 조회7,319회 댓글0건
    private lateinit var permissionLauncher : ActivityResultLauncher<Array<String>>
    private var isAccessCoarseLocationPermissionGranted = false
    private var isReadPermissionGranted = false
    private var isWritePermissionGranted = false
    private var isLocationPermissionGranted = false
    private var isRecordAudioPermissionGranted = false
        permissionLauncher = registerForActivityResult(ActivityResultContracts.RequestMultiplePermissions()){ permissions ->
            isAccessCoarseLocationPermissionGranted = permissions[android.Manifest.permission.ACCESS_COARSE_LOCATION] ?: isAccessCoarseLocationPermissionGranted
            isReadPermissionGranted = permissions[android.Manifest.permission.ACCESS_FINE_LOCATION] ?: isReadPermissionGranted
            isWritePermissionGranted = permissions[android.Manifest.permission.READ_EXTERNAL_STORAGE] ?: isWritePermissionGranted
            isLocationPermissionGranted = permissions[android.Manifest.permission.WRITE_EXTERNAL_STORAGE] ?: isLocationPermissionGranted
            isRecordAudioPermissionGranted = permissions[android.Manifest.permission.RECORD_AUDIO] ?: isRecordAudioPermissionGranted
            //자리에 맞게 재요청 할 내용 Toast표시 및 requestPermission다시 보내기 등 하면 되는 자리
        selfCheckPermission()
        requestPermission()
    //권한 없는것 요청
    private fun requestPermission() {
        val permissionRequest : MutableList<String> = ArrayList()
        if(!isAccessCoarseLocationPermissionGranted){ permissionRequest.add(android.Manifest.permission.ACCESS_COARSE_LOCATION) }
        if(!isLocationPermissionGranted)            { permissionRequest.add(android.Manifest.permission.ACCESS_FINE_LOCATION) }
        if(!isReadPermissionGranted)                { permissionRequest.add(android.Manifest.permission.READ_EXTERNAL_STORAGE) }
        if(!isWritePermissionGranted)              { permissionRequest.add(android.Manifest.permission.WRITE_EXTERNAL_STORAGE) }
        if(!isRecordAudioPermissionGranted)        { permissionRequest.add(android.Manifest.permission.RECORD_AUDIO) }
        //없는 권한 ArrayList로 만들어 Launch로 MultiPermission열기
        if(permissionRequest.isNotEmpty()){permissionLauncher.launch(permissionRequest.toTypedArray())}
    //권한 등록되어있는지 체크
    private fun selfCheckPermission() {
        //위치 기반 권한 체크
        isAccessCoarseLocationPermissionGranted = ContextCompat.checkSelfPermission(this, android.Manifest.permission.ACCESS_COARSE_LOCATION
        ) == PackageManager.PERMISSION_GRANTED
        isLocationPermissionGranted = ContextCompat.checkSelfPermission(this, android.Manifest.permission.ACCESS_FINE_LOCATION
        //저장소 일기 권한 체크
        isReadPermissionGranted = ContextCompat.checkSelfPermission(this, android.Manifest.permission.READ_EXTERNAL_STORAGE
        //저장소 쓰기 권한 체크
        val isWritePermission = ContextCompat.checkSelfPermission(this, android.Manifest.permission.WRITE_EXTERNAL_STORAGE
        val minSdkLevel = Build.VERSION.SDK_INT >= Build.VERSION_CODES.Q //쓰기 권한은 28이후에 나왔으므로
        isWritePermissionGranted = isWritePermission || minSdkLevel
        //오디오
        isRecordAudioPermissionGranted = ContextCompat.checkSelfPermission(this, android.Manifest.permission.RECORD_AUDIO
 ***  AndroidManifest.xml
<!--추가한 부분-->
    <uses-permission android:name="android.permission.READ_EXTERNAL_STORAGE"/>
    <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" android:maxSdkVersion="28"/> <!-- 28 이상은 쓰기 권한 을 받을 필요가 없다-->
    <uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
    <uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION"/>
    <uses-permission android:name="android.permission.CAMERA"/>
    <uses-feature android:name="android.hardware.camera" android:required="true"/>
