Kotlin 고급 위젯 - 뷰 컨테이너(View Container) : 라디오버튼(RadioButton)
작성자 임베디드코리아 작성일23-09-24 02:39 조회7,060회 댓글0건
        android:layout_width="400dp"
        android:layout_height="50dp"
        android:text="필요한 색을 선택하세요."
        android:textSize="20sp"
        android:textStyle="bold"
        app:layout_constraintBottom_toTopOf="@+id/radioGroup"
        tools:layout_editor_absoluteX="149dp" />
    <RadioGroup
        android:id="@+id/radioGroup"
        android:paddingStart="20dp"
        android:paddingEnd="20dp"
        app:layout_constraintEnd_toEndOf="parent">
        <RadioButton
            android:id="@+id/radioColor1"
            android:padding="10dp"
            android:text="@string/red"/>
        <RadioButton
            android:id="@+id/radioColor2"
            android:text="@string/blue"/>
        <RadioButton
            android:id="@+id/radioColor3"
            android:text="@string/green"/>
    </RadioGroup>
    private lateinit var binding: ActivityMainBinding
        binding = ActivityMainBinding.inflate(layoutInflater)
        val view = binding.root
        setContentView(view)
        setOnCheckedChangeListener()
    private fun setOnCheckedChangeListener() {
        binding.radioGroup.setOnCheckedChangeListener { group, checkedId ->
            when (checkedId) {
                R.id.radioColor1-> {
                  Toast.makeText(applicationContext, "RED 버튼이 선택되었습니다.", Toast.LENGTH_SHORT).show()
                R.id.radioColor2-> {
                    Toast.makeText(applicationContext, "BLUE 버튼이 선택되었습니다.", Toast.LENGTH_SHORT).show()
                R.id.radioColor3-> {
                    Toast.makeText(applicationContext, "GREEN 버튼이 선택되었습니다.", Toast.LENGTH_SHORT).show()
            //Toast.makeText(this, "RED 버튼이 선택되었습니다.", Toast.LENGTH_SHORT).show()
          // Toast.makeText(applicationContext, text, Toast.LENGTH_SHORT).show()
    strings.xml.kt
<resources>
    <string name="app_name">RadioButtonBindingKotlin</string>
    <string name="red">빨강</string>
    <string name="blue">파랑</string>
    <string name="green">초록</string>
