Kotlin 인텐트(intent) : 암시적 인텐트 (Implicit Intent)-Data 전달하기
작성일 23-10-23 22:55
조회6,347회
메인 Activity에서 Second Activity로 데이터 전달하기
android:id="@+id/editText"
android:layout_width="0dp"
android:layout_margin="20dp"
android:layout_marginStart="20dp"
android:layout_marginEnd="20dp"
android:hint="텍스트를 입력하세요"
app:layout_constraintBottom_toTopOf="@+id/GoSecondActivityBTN"
app:layout_constraintHorizontal_bias="0.0"
android:id="@+id/GoSecondActivityBTN"
android:layout_marginBottom="400dp"
android:text="Go SecondActivity"
***** activity_second.xml **
--- res/layout 에서 ---> New --> Layout Resource File
--- File : activity_sub , Source set : main
android:orientation="vertical" >
android:id="@+id/reciveData"
android:layout_marginTop="30dp"/>
android:id="@+id/ReturnBTN"
android:layout_marginTop="20dp"
android:text="돌아가기" />
private lateinit var SecondActivityBTN: Button
private lateinit var messageET: EditText
title ="암시적 인텐트 호출"
SecondActivityBTN = findViewById(R.id.GoSecondActivityBTN)
messageET = findViewById(R.id.editText)
SecondActivityBTN.setOnClickListener {
val intent = Intent( "intent.implicit.second")
intent.putExtra("KEY",messageET.text.toString())
//intent.putExtra("KEY", "쫓기는 짐승이 되지 말고, 싸우는 영웅이 되자 !")
startActivity(intent)
messageET.setOnClickListener {
messageET.setText(null)
***** SecondActivity.kt **
-- New --> Kotlin Class/File
-- Name : SecondActivity
class SecondActivity: AppCompatActivity() {
private lateinit var btnReturn: Button
private lateinit var textView: TextView
setContentView(R.layout.activity_second)
title = "암시적 Second 액티비티"
btnReturn = findViewById<Button>(R.id.ReturnBTN)
textView = findViewById<TextView>(R.id.reciveData)
var ReciveMSG = this.intent.getStringExtra("KEY") //전송부의 키값의 value를 가져온다.
Toast.makeText(applicationContext, "메인로 부터 데이터를 받았습니다.", Toast.LENGTH_LONG).show()
textView.text="$ReciveMSG"
btnReturn.setOnClickListener {
//setResult(2900)
finish()
<style name="Base.Theme.ImplicitIntentAtivityData" parent="Theme.AppCompat.Light">
<item name="colorPrimary">#2196F3</item>
<item name="colorPrimaryDark">#FFC107</item>
<style name="Theme.ImplicitIntentAtivityData" parent="Base.Theme.ImplicitIntentAtivityData" />
AndroidManifest.xml
추가하기
<activity
android:name=".SecondActivity"
android:exported="true" >
<intent-filter>
<action android:name="intent.implicit.second" />
<category android:name="android.intent.category.DEFAULT" />
</intent-filter>
</activity>
