간단 웹브라우저 만들기.
작성자 임베디드코리아 작성일23-10-16 22:37 조회6,727회 댓글0건
    <LinearLayout
        android:id="@+id/linearLayout1"
        android:layout_height="wrap_content" >
            android:id="@+id/edtUrl"
            android:layout_weight="1"
            android:hint="URL을 입력하세요."
            android:singleLine="true" >
        </EditText>
            android:id="@+id/btnGo"
            android:text="이동" />
            android:id="@+id/btnBack"
            android:text="이전" />
    <WebView
        android:id="@+id/webView1"
        android:clickable="true" />
    lateinit internal var edtUrl : EditText
    lateinit internal var btnGo : Button
    lateinit internal var btnBack : Button
    lateinit internal var web : WebView
        getSupportActionBar()!!.setDisplayShowHomeEnabled(true)
        getSupportActionBar()!!.setIcon(R.drawable.web)
        edtUrl = findViewById<EditText>(R.id.edtUrl)
        btnGo = findViewById<Button>(R.id.btnGo)
        btnBack = findViewById<Button>(R.id.btnBack)
        web = findViewById<WebView>(R.id.webView1)
        web.webViewClient = CookWebViewClient()
        var webSet = web.settings
        webSet.builtInZoomControls = true
        btnGo.setOnClickListener {
            web.loadUrl(edtUrl.text.toString())
        btnBack.setOnClickListener {
            web.goBack()
    class CookWebViewClient : WebViewClient1() {
        @Deprecated("Deprecated in Java")
        override fun shouldOverrideUrlLoading(view: WebView?, url: String?): Boolean {
            return super.shouldOverrideUrlLoading(view, url)
 ***  AndroidManifest.xml
 <uses-permission android:name="android.permission.INTERNET"/>
<application
        android:label="간단 웹브라우저"
        android:theme="@style/Theme.AppCompat.Light.DarkActionBar"
