Kotlin 대화상자(Dialog) : 알림 대화상자(AlertDialog) 체크박스(Check Box)형
작성자 임베디드코리아 작성일23-09-25 01:09 조회6,642회 댓글0건
        android:id="@+id/button"
        android:text="Dialog띄우기" />
    private lateinit var binding: ActivityMainBinding
        binding = ActivityMainBinding.inflate(layoutInflater)
        val view = binding.root
        setContentView(view)
        binding.button.setOnClickListener {
            val items = arrayOf("곰", "사자", "호랑이", "독수리")
            val selectedItemIndex = ArrayList<Int>()
            val builder = AlertDialog.Builder(this)
                .setTitle("좋아하는 동물?")
                .setMultiChoiceItems(items, null){ dialog, which, bool ->
                    if(bool){
                        selectedItemIndex.add(which)
                    }else if(selectedItemIndex.contains(which)){
                        selectedItemIndex.remove(which)
                .setPositiveButton("확인",
                    DialogInterface.OnClickListener { dialog, which ->
                        val selectedItems = ArrayList<String>()
                        for(i in selectedItemIndex){
                            selectedItems.add(items[i])
                        Toast.makeText(this, selectedItems.toString(), Toast.LENGTH_SHORT).show()
            builder.show()
  build.gradle(Module) : build.gradle.kts
// 안드로이드 스튜디오 4.0 이상
android {
    buildFeatures {
        viewBinding = true
