Kotlin 고급 위젯 - 기 타: 프로그레스바(ProgressBar)
작성자 임베디드코리아 작성일23-09-24 01:37 조회6,652회 댓글0건
    <LinearLayout
        <ProgressBar
            android:id="@+id/pb1"
            style="@android:style/Widget.DeviceDefault.Light.ProgressBar.Large"
            android:indeterminateTint="#FF00D5"
            android:layout_gravity="center_horizontal"
            android:layout_marginLeft="10dp"
            android:layout_marginTop="100dp"/>
        <ProgressBar
            android:id="@+id/pb2"
            android:indeterminateTint="#00E1FF"
            android:layout_marginTop="50dp" />
        <ProgressBar
            android:id="@+id/pb3"
            style="@android:style/Widget.DeviceDefault.ProgressBar.Small"
            android:indeterminateTint="#FFB300"
    <ProgressBar
        android:id="@+id/pb4"
        style="@style/Widget.AppCompat.ProgressBar.Horizontal"
        android:scaleY="5"
        android:progressBackgroundTint="#00EAFF"
        android:progressTint="#3949AB"
    <LinearLayout
        android:orientation="horizontal">
            android:id="@+id/btn"
            android:text="5만큼 증가"
            android:id="@+id/btn2"
            android:layout_marginLeft="20dp"
            android:layout_marginTop="50dp"/>
            android:id="@+id/btn3"
            android:text="50으로 설정"
    <ProgressBar
        android:id="@+id/progressbar"
        style="@style/Widget.AppCompat.ProgressBar"
        android:layout_width="100dp"
        android:layout_height="100dp"
        android:layout_gravity="center"
        android:layout_marginTop="48dp"
        android:indeterminate="false"
        android:max="100"
        android:progressBackgroundTint="#D81B60"
        android:progressTint="#4166ED" />
    private lateinit var btn: Button
    private lateinit var btn2: Button
    private lateinit var btn3: Button
    private lateinit var pb4: ProgressBar
        btn= findViewById(R.id.btn)
        btn2= findViewById(R.id.btn2)
        btn3= findViewById(R.id.btn3)
        pb4= findViewById(R.id.pb4)
        // 별다른 리스너가 존재하지 않는다.
        btn.setOnClickListener { view ->
            pb4.incrementProgressBy(5)
        btn2.setOnClickListener { view ->
            pb4.incrementProgressBy(-5)
        btn3.setOnClickListener { view ->
            pb4.progress = 50
