Kotlin 메뉴(Menu) : 옵션 메뉴(option menu)-배경색 변경 앱
작성자 임베디드코리아 작성일23-11-16 11:46 조회6,131회 댓글0건
배경색 변경 앱 만들기
    android:id="@+id/baseLayout"
    android:gravity="center_horizontal"
        android:text="오른쪽 위 메뉴 버튼을 누르세요"
        android:textSize="20dp" />
        android:id="@+id/button1"
        android:text="이건 버튼" />
    lateinit var baseLayout : LinearLayout
    lateinit var button1 : Button
        title = "배경색 바꾸기"
        baseLayout = findViewById<LinearLayout>(R.id.baseLayout)
        button1 = findViewById<Button>(R.id.button1)
    override fun onCreateOptionsMenu(menu: Menu?) : Boolean {
        var mInflater = menuInflater
        mInflater.inflate(R.menu.menu1, menu)
        return true
    override fun onOptionsItemSelected(item: MenuItem) : Boolean {
        when (item.itemId) {
            R.id.itemRed -> {
                baseLayout.setBackgroundColor(Color.RED)
                return true
            R.id.itemGreen -> {
                baseLayout.setBackgroundColor(Color.GREEN)
                return true
            R.id.itemBlue -> {
                baseLayout.setBackgroundColor(Color.BLUE)
                return true
            R.id.subRotate -> {
                button1.rotation = 45f
                return true
            R.id.subSize -> {
                button1.scaleX = 2f
                return true
        return false
*****  menu1.xml  * ******
 menu 폴더 만들기  -->  New ---> Android Resource Directory
 menu.xml 만들기  -->  New ---> Menu Resource File
<menu xmlns:android="http://schemas.android.com/apk/res/android">
    <item
        android:id="@+id/itemRed"
        android:title="배경색 (빨강)">
    </item>
    <item
        android:id="@+id/itemGreen"
        android:title="배경색(초록)">
    </item>
    <item
        android:id="@+id/itemBlue"
        android:title="배경색(파랑)">
    </item>
    <item android:title="버튼 변경 >> ">
        <menu>
            <item
                android:id="@+id/subRotate"
                android:title="버튼 45도 회전"/>
            <item
                android:id="@+id/subSize"
                android:title="버튼 2배 확대"/>
        </menu>
    </item>
</menu>
*****      themes.xml  **********
    <style name="Base.Theme.MenuOptionmenu" parent="Theme.MaterialComponents.DayNight.DarkActionBar">
        <item name="colorPrimary">#7CB342</item>
    <style name="Theme.MenuOptionmenu" parent="Base.Theme.MenuOptionmenu" />
