Kotlin 대화상자(Dialog) : 라디오버튼
작성자 임베디드코리아 작성일23-10-30 21:51 조회6,100회 댓글0건
        android:id="@+id/button1"
        android:layout_marginTop="112dp"
        android:background="@drawable/button"
        android:text="대화상자"
        app:layout_constraintHorizontal_bias="0.498"
        app:layout_constraintVertical_bias="0.057" />
    botton.xml
-- res/drawable
-- File Name : button  , Root Element : shape
    android:padding="10dp"
    android:shape="rectangle" >
    <corners
        android:radius="30dp"
        android:topLeftRadius="30dp"
</shape>
        val button1 = findViewById<View>(R.id.button1) as Button
        button1.setOnClickListener {
            var versionArray = arrayOf("오레오", "파이", "큐(10)")
            var dlg = AlertDialog.Builder(this@MainActivity)
            dlg.setTitle("좋아하는 버전은?")
            dlg.setIcon(R.mipmap.ic_launcher)
            dlg.setSingleChoiceItems(versionArray, 0) { dialog, which ->
                button1.text = versionArray[which]
            dlg.setPositiveButton("닫기", null)
            dlg.show()
    <style name="Base.Theme.RadioButtonDialog" parent="Theme.AppCompat.Light">
        <item name="colorPrimaryDark">#9C27B0</item>
    <style name="Theme.RadioButtonDialog" parent="Base.Theme.RadioButtonDialog" />
