Kotlin 대화상자(Dialog) : 기본 알림 대화상자(AlertDialog)
작성자 임베디드코리아 작성일23-10-30 19:01 조회6,356회 댓글0건
    android:gravity="center_horizontal"
        android:id="@+id/button1"
        android:text="대화상자"
        android:background="@drawable/button" />
    botton.xml
-- res/drawable
-- File Name : button  , Root Element : shape
    android:padding="10dp"
    android:shape="rectangle" >
    <corners
        android:radius="30dp"
        android:topLeftRadius="30dp"
</shape>
        var button1 = findViewById<Button>(R.id.button1)
        button1.setOnClickListener {
            var dlg = AlertDialog.Builder(this@MainActivity)
            dlg.setTitle("제목입니다")
            dlg.setMessage("이곳이 내용입니다")
            dlg.setIcon(R.mipmap.ic_launcher)
            dlg.show()
    <style name="Base.Theme.AlertDialogBase" parent="Theme.AppCompat.Light">
        <item name="colorPrimaryDark">#FF5722</item>
    <style name="Theme.AlertDialogBase" parent="Base.Theme.AlertDialogBase" />
