작성일23-10-23 23:34
조회6,387회
Kotlin 멀티미디어 : 음성 녹음 하기
<LinearLayout
xmlns:android="http://schemas.android.com/apk/res/android"
android:id="@+id/button_start"
android:background="@drawable/confirm_botton"
android:text="녹음 시작"
android:layout_marginLeft="30dp"
android:layout_marginRight="30dp"/>
android:id="@+id/button_stop"
android:text="녹음 마침"
botton_true.xml
-- res/drawable
-- File Name : button_true , Root Element : shape
android:padding="10dp"
android:shape="rectangle" >
<corners
android:radius="30dp"
android:topLeftRadius="30dp"
</shape>
botton_false.xml
-- res/drawable
-- File Name : button_farse , Root Element : shape
<solid android:color="#FFC107" />
<corners
</shape>
confirm_botton.xml
-- res/drawable
-- File Name : confirm_botton , Root Element : selector
<selector xmlns:android="http://schemas.android.com/apk/res/android">
<item android:state_pressed="true" android:drawable="@drawable/button_false"></item>
<item android:state_pressed="false" android:drawable="@drawable/button_true"></item>
</selector>
private var outputPath: String? = null
private var mediaRecorder : MediaRecorder? = null
private var state : Boolean = false
title = "음성 녹음 하기"
val startBtn = findViewById<Button>(R.id.button_start)
val stopBtn = findViewById<Button>(R.id.button_stop)
// 녹음 시작 버튼
startBtn.setOnClickListener {
// 권한 부여 여부
val isEmpower = ContextCompat.checkSelfPermission(this,
android.Manifest.permission.RECORD_AUDIO) != PackageManager.PERMISSION_GRANTED && ContextCompat.checkSelfPermission(this,
android.Manifest.permission.WRITE_EXTERNAL_STORAGE) != PackageManager.PERMISSION_GRANTED
// 권한 부여 되지 않았을경우
if (isEmpower) {
empowerRecordAudioAndWriteReadStorage()
// 권한 부여 되었을 경우
} else {
startRecording()
// 녹음 중지 버튼
stopBtn.setOnClickListener {
stopRecording()
// 레코딩, 파일 읽기 쓰기 권한부여
private fun empowerRecordAudioAndWriteReadStorage(){
val permissions = arrayOf(android.Manifest.permission.RECORD_AUDIO, android.Manifest.permission.WRITE_EXTERNAL_STORAGE, android.Manifest.permission.READ_EXTERNAL_STORAGE)
ActivityCompat.requestPermissions(this, permissions,0)
private fun startRecording(){
val fileName: String = Date().getTime().toString() + ".mp3"
outputPath = Environment.getExternalStorageDirectory().absolutePath + "/Download/" + fileName //내장메모리 밑에 위치
mediaRecorder = MediaRecorder()
mediaRecorder?.setAudioSource((MediaRecorder.AudioSource.MIC))
mediaRecorder?.setOutputFormat((MediaRecorder.OutputFormat.MPEG_4))
mediaRecorder?.setAudioEncoder(MediaRecorder.AudioEncoder.AAC)
mediaRecorder?.setOutputFile(outputPath)
try {
mediaRecorder?.prepare()
mediaRecorder?.start()
state = true
Toast.makeText(this, "녹음이 시작되었습니다.", Toast.LENGTH_SHORT).show()
} catch (e: IllegalStateException){
e.printStackTrace()
} catch (e: IOException){
e.printStackTrace()
private fun stopRecording(){
if(state){
mediaRecorder?.stop()
mediaRecorder?.reset()
mediaRecorder?.release()
state = false
Toast.makeText(this, "녹음이 되었습니다.", Toast.LENGTH_SHORT).show()
} else {
Toast.makeText(this, "녹음 상태가 아닙니다.", Toast.LENGTH_SHORT).show()
<style name="Base.Theme.VoiceRecorder" parent="Theme.AppCompat.Light">
<style name="Theme.VoiceRecorder" parent="Base.Theme.VoiceRecorder" />
