작성일23-10-23 23:32
조회6,370회
Kotlin 멀티미디어 : 음악 듣기
1) 버튼을 이용한 음악 듣기
android:id="@+id/plyaButton"
android:text="PLAY"
lateinit var playBTN: Button
var mediaplayer : MediaPlayer?= null
title = "음악 듣기"
playBTN = findViewById(R.id.plyaButton)
mediaplayer = MediaPlayer.create(this, R.raw.sample)
//버튼을 클릭하면 mp3를 재생하도록 하자.
playBTN.setOnClickListener {
//재생할 파일을 준비한다.
mediaplayer?.start()
override fun onDestroy () {
super.onDestroy ()
mediaplayer?.release ()
<style name="Base.Theme.MultiMediaMusic" parent="Theme.AppCompat.Light">
<!-- <item name="colorPrimary">@color/my_light_primary</item> -->
<style name="Theme.MultiMediaMusic" parent="Base.Theme.MultiMediaMusic" />
2) Switch를 이용한 음악 듣기
<Switch
android:id="@+id/switch1"
android:text="음악듣기"
app:layout_constraintTop_toTopOf="parent"/>
title = "음악 듣기"
var mPlayer: MediaPlayer
mPlayer = MediaPlayer.create(this, R.raw.sample)
var switch1 = findViewById<Switch>(R.id.switch1)
switch1.setOnClickListener {
if (switch1.isChecked == true)
mPlayer.start()
else
mPlayer.stop()
<style name="Base.Theme.MultiMediaSwitchMP3" parent="Theme.AppCompat.Light">
<style name="Theme.MultiMediaSwitchMP3" parent="Base.Theme.MultiMediaSwitchMP3" />
