Kotlin 스레드(Thread) : 음악 듣기와 SeekBar를 이용한 Thread
작성일 23-10-23 23:29
조회6,514회
<Switch
android:id="@+id/switch1"
android:layout_marginTop="50dp"
android:text="음악듣기" />
<SeekBar
android:id="@+id/pbMP3"
android:layout_marginTop="20dp"/>
lateinit var mPlayer: MediaPlayer
lateinit var pbMP3: SeekBar
lateinit var switch1: Switch
pbMP3 = findViewById<SeekBar>(R.id.pbMP3)
switch1 = findViewById<Switch>(R.id.switch1)
switch1.setOnClickListener {
if (switch1.isChecked == true) {
mPlayer = MediaPlayer.create(applicationContext, R.raw.song1)
mPlayer.start()
makeThread()
} else {
mPlayer.stop()
pbMP3.setOnSeekBarChangeListener(object : SeekBar.OnSeekBarChangeListener {
override fun onStopTrackingTouch(seekBar: SeekBar) {}
override fun onStartTrackingTouch(seekBar: SeekBar) {}
override fun onProgressChanged(seekBar: SeekBar, progress: Int, fromUser: Boolean) {
if (fromUser) {
mPlayer.seekTo(progress)
fun makeThread() {
object : Thread() {
override fun run() {
// ۵ ̶
while (mPlayer.isPlaying) {
pbMP3.max = mPlayer.duration // ð ִ
pbMP3.progress = mPlayer.currentPosition // ġ
SystemClock.sleep(100)
pbMP3.progress = 0
}.start()
<style name="Base.Theme.ThreadMusicSeekBar" parent="Theme.AppCompat.Light">
<item name="colorPrimary">#FFC107</item>
<item name="colorPrimaryDark">#E91E63</item>
<style name="Theme.ThreadMusicSeekBar" parent="Base.Theme.ThreadMusicSeekBar" />
