Kotlin 브로드캐스트 리시버 : 배터리 상태를 표시
작성자 임베디드코리아 작성일23-10-23 23:09 조회6,374회 댓글0건
Kotlin 브로드캐스트 리시버(Broadcast Receiver,BR) : 배터리 상태를 표시
배터리 상태가 변할 때마다 충전 상태 이미지와 배터리 상태를 출력
    <ImageView
        android:id="@+id/ivBattery"
        android:src="@drawable/battery_0"
        android:layout_marginTop="30dp"
        android:layout_marginLeft="10dp"/>
        android:id="@+id/edtBattery"
        android:background="#ffdab9"
        android:textColor="#000000"
        android:enabled="false" />
    lateinit var ivBattery: ImageView
    lateinit var edtBattery: EditText
        title = "배터리 상태 체크"
        ivBattery = findViewById<ImageView>(R.id.ivBattery)
        edtBattery = findViewById<EditText>(R.id.edtBattery)
    var br: BroadcastReceiver = object : BroadcastReceiver() {
        override fun onReceive(context: Context, intent: Intent) {
            var action = intent.action
            if (action == Intent.ACTION_BATTERY_CHANGED) {
                var remain = intent.getIntExtra(BatteryManager.EXTRA_LEVEL, 0)
                edtBattery.setText("현재 충전량 : $remain\n")
                if (remain >= 90)
                    ivBattery.setImageResource(R.drawable.battery_100)
                else if (remain >= 70)
                    ivBattery.setImageResource(R.drawable.battery_80)
                else if (remain >= 50)
                    ivBattery.setImageResource(R.drawable.battery_60)
                else if (remain >= 10)
                    ivBattery.setImageResource(R.drawable.battery_20)
                else
                    ivBattery.setImageResource(R.drawable.battery_0)
                var plug = intent.getIntExtra(BatteryManager.EXTRA_PLUGGED, 0)
                when (plug) {
                    0 -> edtBattery.append("전원 연결 : 안됨")
                    BatteryManager.BATTERY_PLUGGED_AC -> edtBattery.append("전원 연결 : 어댑터 연결됨")
                    BatteryManager.BATTERY_PLUGGED_USB -> edtBattery.append("전원 연결 : USB 연결됨")
    override fun onPause() {
        super.onPause()
        unregisterReceiver(br)
    override fun onResume() {
        super.onResume()
        var iFilter = IntentFilter()
        iFilter.addAction(Intent.ACTION_BATTERY_CHANGED)
        iFilter.addAction(Intent.ACTION_SCREEN_ON)
        registerReceiver(br, iFilter)
    <style name="Base.Theme.BroadCastBattery" parent="Theme.AppCompat.Light">
        <!-- <item name="colorPrimary">@color/my_light_primary</item> -->
    <style name="Theme.BroadCastBattery" parent="Base.Theme.BroadCastBattery" />
