Kotlin 인텐트(intent) : 명시적 인텐트(Explicit Intent) - 양방향 데이터 전달하기
작성자 임베디드코리아 작성일23-10-23 22:51 조회7,049회 댓글0건
- 양방향 데이터 전달하기
        android:id="@+id/edtNum1"
        android:layout_width="200dp"
        android:background="#CFFBED"
        android:layout_marginLeft="80dp">
    </EditText>
        android:id="@+id/edtNum2"
        android:background="#F4F0CC"
        android:layout_marginTop="20dp"
        android:layout_marginLeft="80dp"/>
        android:id="@+id/btnNewActivity"
        android:layout_marginTop="50dp"
        android:text="Second Activiy에서 더하기" />
*****      activity_second.xml **
--- res/layout 에서  ---> New  --> XML --> Layout XML File
--- Layout File Name : activity_second  ,  Root Tag : main
    android:orientation="vertical" >
        android:id="@+id/reciveData"
        android:layout_marginTop="30dp"/>
        android:id="@+id/btnReturn"
        android:background="@drawable/button"
        android:text="돌아가기" />
        title = "메인 액티비티"
        var btnNewActivity = findViewById<Button>(R.id.btnNewActivity)
        btnNewActivity.setOnClickListener {
            var edtNum1 = findViewById<EditText>(R.id.edtNum1)
            var edtNum2 = findViewById<EditText>(R.id.edtNum2)
            var intent = Intent(applicationContext, SecondActivity::class.java)
            intent.putExtra("Num1", edtNum1.text.toString())
            intent.putExtra("Num2", edtNum2.text.toString())
            //intent.putExtra("Num1", Integer.parseInt(edtNum1.text.toString()))
            //intent.putExtra("Num2", Integer.parseInt(edtNum2.text.toString()))
            startActivityForResult(intent, 0)
            edtNum1.setOnClickListener  {
                edtNum1.setText(null)
            edtNum2.setOnClickListener  {
                edtNum2.setText(null)
    override fun onActivityResult(requestCode: Int, resultCode: Int, data: Intent?) {
        super.onActivityResult(requestCode, resultCode, data)
        if (resultCode == Activity.RESULT_OK) {
            var hap = data!!.getIntExtra("Hap", 0)
            Toast.makeText(applicationContext, "합계 :$hap", Toast.LENGTH_SHORT).show()
*****    SecondActivity.kt **
-- New --> Kotlin Class/File
-- Name : SecondActivity
class SecondActivity : AppCompatActivity() {
    lateinit var  reciveData1: String
    lateinit var  reciveData2: String
        setContentView(R.layout.activity_second)
        title = "Second 액티비티"
        var btnReturn = findViewById<Button>(R.id.btnReturn)
        var textView = findViewById<TextView>(R.id.reciveData)
        var inIntent = intent
        reciveData1 = inIntent.getStringExtra("Num1").toString()
        reciveData2 = inIntent.getStringExtra("Num2").toString()
        textView.text="    Main Activity로 부터 받은 값은 $reciveData1 와 $reciveData2 입니다." +
                "\n"+"    되돌아가기 버튼을 클릭하면, " +
                "\n"+"    더하기 한 값을 Main Activity로 보냄니다."
        //var hapValue = inIntent.getIntExtra("Num1", 0) + inIntent.getIntExtra("Num2", 0)
        var hapValue = reciveData1.toInt()+reciveData2.toInt()
        btnReturn.setOnClickListener {
            var outIntent = Intent(applicationContext, MainActivity::class.java)
            outIntent.putExtra("Hap", hapValue)
            setResult(Activity.RESULT_OK, outIntent)
            finish()
    AndroidManifest.xml
        추가하기
        <activity
            android:name=".SubActivity" >
        </activity>
    botton.xml
-- res/drawable
-- File Name : button  , Root Element : shape
    android:padding="10dp"
    android:shape="rectangle" >
    <corners
        android:radius="30dp"
        android:topLeftRadius="30dp"
</shape>
    <style name="Base.Theme.ExplicitIntentDuplexData" parent="Theme.AppCompat.Light">
    <style name="Theme.ExplicitIntentDuplexData" parent="Base.Theme.ExplicitIntentDuplexData" />
