Kotlin 인텐트(intent) : 명시적 인텐트(Explicit Intent)-데이터 전달하기
작성자 임베디드코리아 작성일23-10-23 22:50 조회7,026회 댓글0건
- Sub Activity로 데이터 전달하기
        android:id="@+id/editText"
        android:layout_width="0dp"
        android:layout_margin="20dp"
        android:layout_marginStart="20dp"
        android:layout_marginTop="352dp"
        android:layout_marginEnd="20dp"
        android:hint="텍스트를 입력하세요"
        app:layout_constraintBottom_toTopOf="@+id/btnGoSubActivity"
        app:layout_constraintHorizontal_bias="0.0"
        android:id="@+id/btnGoSubActivity"
        android:layout_marginBottom="236dp"
        android:text="Go SubActivity"
*****      activity_sub.xml **
--- res/layout 에서  ---> New  --> Layout Resource File
--- File : activity_sub  ,  Source set : main
    tools:context=".SubActivity" >
        android:id="@+id/textView"
        android:text="수신된 문자열"
        android:textSize="20sp"
        android:gravity="center"
        app:layout_constraintBottom_toTopOf="@+id/btnClose"
        android:id="@+id/btnClose"
        android:text="Close"
    private lateinit var btnGoSubActivity: Button
    private lateinit var editText: EditText
        btnGoSubActivity = findViewById(R.id.btnGoSubActivity)
        editText = findViewById(R.id.editText)
        btnGoSubActivity.setOnClickListener {
            val text = editText.text.toString()
            val intent = Intent(this, SubActivity::class.java)
            intent.putExtra("Data", text)
            startActivity(intent)
*****    SubActivity.kt **
-- New --> Kotlin Class/File
-- Name : SubActivity
class SubActivity: AppCompatActivity() {
    private lateinit var textView: TextView
    private lateinit var btnClose: Button
        setContentView(R.layout.activity_sub)
        textView = findViewById(R.id.textView)
        btnClose = findViewById(R.id.btnClose)
        textView.text = intent.getStringExtra("Data")
        btnClose.setOnClickListener {
            finish()
    AndroidManifest.xml
        추가하기
        <activity
            android:name=".SubActivity" >
        </activity>
