Kotlin 인텐트(intent) : 명시적 인텐트(Explicit Intent) - 기본 인텐트
작성자 임베디드코리아 작성일23-10-23 22:47 조회7,591회 댓글0건
- 기본적인 인텐트로 버튼을 클릭하면  Sub Activity 를 수행하고, 버튼을 클릭하면 다시 뒤돌온다.
        android:text="Main Activity"
        app:layout_constraintLeft_toLeftOf="parent"
        app:layout_constraintRight_toRightOf="parent"
        android:id="@+id/btnGoSubActivity"
        android:text="Go to SubActivity"
        android:layout_marginBottom="20dp"
*****      activity_sub.xml **
--- res/layout 에서  ---> New  --> Layout Resource File
--- File : activity_sub  ,  Source set : main
    android:background="#E1DCB0"
    tools:context=".SubActivity">
        android:text=" 여기는 \n Sub Activity \n 입니다."
        android:id="@+id/btnClose"
        android:text="Go Back"
    private lateinit var btnGoSubActivity: Button
        btnGoSubActivity = findViewById(R.id.btnGoSubActivity)
        btnGoSubActivity.setOnClickListener {
            val intent = Intent(this, SubActivity::class.java)
            startActivity(intent)
*****    SubActivity.kt **
-- New --> Kotlin Class/File
-- Name : SubActivity
class SubActivity : AppCompatActivity() {
    private lateinit var btnClose: Button
        setContentView(R.layout.activity_sub)
        btnClose = findViewById(R.id.btnClose)
        btnClose.setOnClickListener {
            finish()
    AndroidManifest.xml
        추가하기
        <activity
            android:name=".SubActivity" >
        </activity>
