Kotlin 이미지(Image) : 블러링(blurring) 앱바(App Bar)
작성자 임베디드코리아 작성일23-10-20 21:05 조회7,270회 댓글0건
    private lateinit var mgv: MyGraphicView
        mgv = MyGraphicView(this)
        setContentView(mgv)
    override fun onCreateOptionsMenu(menu: Menu?): Boolean {
        menu?.add(0, 1, 0, "NORMAL")
        menu?.add(0, 2, 0, "INNER")
        menu?.add(0, 3, 0, "OUTER")
        menu?.add(0, 4, 0, "SOLID")
        menu?.add(0, 5, 0, "원래대로")
        return true
    override fun onOptionsItemSelected(item: MenuItem): Boolean {
        when (item.itemId) {
            1 -> {
                choice = 1
                mgv.invalidate()
                return true
            2 -> {
                choice = 2
                mgv.invalidate()
                return true
            3 -> {
                choice = 3
                mgv.invalidate()
                return true
            4 -> {
                choice = 4
                mgv.invalidate()
                return true
            5 -> {
                choice = 5
                mgv.invalidate()
                return true
        return false
*****    MyGraphicView.kt **
class MyGraphicView(context: Context?) : View(context) {
    override fun onDraw(canvas: Canvas) {
        super.onDraw(canvas)
        val picture = BitmapFactory.decodeResource(resources, R.drawable.durumi)
        var picX = (this.width - picture.width) / 2f
        var picY = (this.height - picture.height) / 2f
        var paint = Paint()
        var bMask: BlurMaskFilter
        when (choice) {
            0 -> canvas?.drawBitmap(picture, picX.toFloat(), picY.toFloat(), null)
            //원본대로 읽어와서 표시
            1 -> {
                bMask = BlurMaskFilter(30f, BlurMaskFilter.Blur.NORMAL)
                paint.maskFilter = bMask
                canvas.drawBitmap(picture, picX, picY, paint)
                //NORMAL
            2 -> {
                bMask = BlurMaskFilter(30f, BlurMaskFilter.Blur.INNER)
            3 -> {
                bMask = BlurMaskFilter(30f, BlurMaskFilter.Blur.OUTER)
            4 -> {
                bMask = BlurMaskFilter(30f, BlurMaskFilter.Blur.SOLID)
            5 -> {
        picture.recycle() //해당 이미지를 재사용하겠다라는 의미.
    companion object {
        internal var choice = 0
****    strings.xml
<resources>
    <string name="app_name">이미지 블러링</string>
*****    themes.xml
    <style name="Base.Theme.ImageBlurringAppBar" parent="Theme.MaterialComponents.DayNight.DarkActionBar">
        <item name="colorPrimary">#FB8C00</item>
        <item name="colorPrimaryDark">#FBF986</item>
    <style name="Theme.ImageBlurringAppBar" parent="Base.Theme.ImageBlurringAppBar" />
