작성일23-10-16 22:37
조회7,309회
<LinearLayout
android:id="@+id/linearLayout1"
android:layout_height="wrap_content" >
android:id="@+id/edtUrl"
android:layout_weight="1"
android:hint="URL을 입력하세요."
android:singleLine="true" >
</EditText>
android:id="@+id/btnGo"
android:text="이동" />
android:id="@+id/btnBack"
android:text="이전" />
<WebView
android:id="@+id/webView1"
android:clickable="true" />
lateinit internal var edtUrl : EditText
lateinit internal var btnGo : Button
lateinit internal var btnBack : Button
lateinit internal var web : WebView
getSupportActionBar()!!.setDisplayShowHomeEnabled(true)
getSupportActionBar()!!.setIcon(R.drawable.web)
edtUrl = findViewById<EditText>(R.id.edtUrl)
btnGo = findViewById<Button>(R.id.btnGo)
btnBack = findViewById<Button>(R.id.btnBack)
web = findViewById<WebView>(R.id.webView1)
web.webViewClient = CookWebViewClient()
var webSet = web.settings
webSet.builtInZoomControls = true
btnGo.setOnClickListener {
web.loadUrl(edtUrl.text.toString())
btnBack.setOnClickListener {
web.goBack()
class CookWebViewClient : WebViewClient1() {
@Deprecated("Deprecated in Java")
override fun shouldOverrideUrlLoading(view: WebView?, url: String?): Boolean {
return super.shouldOverrideUrlLoading(view, url)
*** AndroidManifest.xml
<uses-permission android:name="android.permission.INTERNET"/>
<application
android:label="간단 웹브라우저"
android:theme="@style/Theme.AppCompat.Light.DarkActionBar"
