Kotlin 파일처리 : 외부 저장소 : 저장 읽기
작성자 임베디드코리아 작성일23-10-05 01:11 조회6,804회 댓글0건
        android:id="@+id/direct_saveBT"
        android:text="Direct External"/>
        android:id="@+id/dataET"
        android:layout_height="100dp"
        android:hint="Enter your message"/>
        android:id="@+id/external_saveBT"
        android:text="External Save"/>
        android:id="@+id/external_loadBT"
        android:text="Read message" />
        android:id="@+id/tv_output"
        android:layout_height="200dp"
        android:background="#F2F89B"/>
class MainActivity : AppCompatActivity(), View.OnClickListener {
        val read =  findViewById<Button>(R.id.direct_saveBT)
        val write =  findViewById<Button>(R.id.external_saveBT)
        val clear =  findViewById<Button>(R.id.external_loadBT)
        read.setOnClickListener(this)
        write.setOnClickListener(this)
        clear.setOnClickListener(this)
    override fun onClick(view: View?) {
        var dir = Environment.getExternalStoragePublicDirectory(Environment.DIRECTORY_DOCUMENTS).toString() +
                File.separator + "my_folder"
        if(view?.id==R.id.direct_saveBT){
            val EXTERNAL_PATH: String = "/sdcard/Documents"
            var message = "Embedded\nKorea"
            val SDcardFile = SimpleDateFormat("yyyy-MM-dd HH:mm:ss")
            val formatDate = SDcardFile.format(System.currentTimeMillis())
            val filename = "ek"
            //message=formatDate
            //val file = File("$EXTERNAL_PATH/$formatDate.txt")
            val DirFileName = File("$EXTERNAL_PATH/$filename.txt")
            if (!DirFileName.exists()) { DirFileName.createNewFile() }
            val writer = FileWriter(DirFileName.absolutePath)
            val buffer = BufferedWriter(writer)
            buffer.write(message)
            buffer.close()
            Toast.makeText(applicationContext, "direct_saveBT:$formatDate", Toast.LENGTH_LONG).show()
        if(view?.id==R.id.external_saveBT){
            val dataET = findViewById<EditText>(R.id.dataET)
            val file = File(dir)
            if (!file.exists()) {
                file.mkdirs()
            var output = FileOutputStream(dir+ "/sdkfile.txt")
            var dos = DataOutputStream(output)
            var readMessage:String = dataET.text.toString()
            dos.writeUTF(readMessage)
            dos.flush()
            dos.close()
            Toast.makeText(applicationContext, "external_saveBT", Toast.LENGTH_LONG).show()
        if(view?.id==R.id.external_loadBT){
            val dataTV = findViewById<TextView>(R.id.tv_output)
            var input = FileInputStream(dir + "/sdkfile.txt")
            var dis = DataInputStream(input)
            var valueUTF = dis.readUTF()
            dis.close()
            dataTV.text = valueUTF
            Toast.makeText(applicationContext, "Read message", Toast.LENGTH_LONG).show()
    AndroidManifest.xml
<!-- 외부 저장소 읽기 권한 -->
    <uses-permission android:name="android.permission.READ_EXTERNAL_STORAGE"/>
    <!-- 외부 저장소 쓰기 권한 -->
    <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"/>
