Kotlin 토스트(Toast)
작성자 임베디드코리아 작성일23-09-25 00:24 조회6,802회 댓글0건
Kotlin    토스트(Toast)
    <LinearLayout
        android:gravity="center"
        android:padding="5dp"
        android:orientation="horizontal">
            android:id="@+id/btn_ToastSHORT"
            android:text="POP Toast SHORT"
            android:textAllCaps="false"
            android:padding="15dp"
            android:textSize="20dp"
            android:layout_height="wrap_content" />
            android:id="@+id/btn_ToastLONG"
            android:text="POP Toast LONG"
        var btnToastshort : Button = findViewById(R.id.btn_ToastSHORT)
        var btnToastlong : Button = findViewById(R.id.btn_ToastLONG)
        btnToastshort.setOnClickListener{
            // Toast.makeText(this, "Toast LENGTH_SHORT", Toast.LENGTH_SHORT).show()
            Toast.makeText(applicationContext, "Toast LENGTH_SHORT", Toast.LENGTH_SHORT).show()
            //Toast.makeText(this@MainActivity, "Toast LENGTH_SHORT", Toast.LENGTH_SHORT).show()
        btnToastlong.setOnClickListener{
            // Toast.makeText(this, "Toast LENGTH_LONG", Toast.LENGTH_LONG).show()
            Toast.makeText(applicationContext, "Toast LENGTH_LONG", Toast.LENGTH_LONG).show()
            //Toast.makeText(this@MainActivity, "Toast LENGTH_LONG", Toast.LENGTH_LONG).show()
