Kotlin 고급 위젯 - 크로노미터(Chronometer): 스톱워치 구현하기
작성자 임베디드코리아 작성일23-09-24 12:59 조회6,891회 댓글0건
    <RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
        android:layout_height="match_parent">
        <Chronometer
            android:id="@+id/chronometer"
            android:gravity="center_horizontal"
            android:textSize="60dp" />
        <ImageView
            android:id="@+id/runImage"
            android:layout_height="100dp"
            android:src="@drawable/run"
            android:layout_below="@+id/chronometer"
            android:layout_marginTop="80dp"
            android:visibility="invisible"/>
        <ImageView
            android:id="@+id/stopImage"
            android:src="@drawable/stop"
        <ImageView
            android:id="@+id/watchImage"
            android:src="@drawable/watch"
            android:layout_marginTop="80dp"/>
        <LinearLayout
            android:orientation="horizontal"
            android:layout_alignParentBottom="true"
            android:layout_marginBottom="70dp">
                android:id="@+id/startButton"
                android:layout_width="100dp"
                android:background="#00897B"
                android:text="START"
                android:textColor="#FFFFFF"
                android:textStyle="bold"
                android:id="@+id/stopButton"
                android:text="STOP"
                android:layout_marginLeft="25dp"
                android:enabled="false"/>
                android:id="@+id/resetButton"
                android:text="RESET"
    </RelativeLayout>
    var initTime = 0L  // 뒤로가기 버튼을 누른 시각을 저장하는 속성
    var pauseTime = 0L  // 멈춘 시간을 저장하는 속성
        val binding = ActivityMainBinding.inflate(layoutInflater)
        setContentView(binding.root)
        binding.startButton.setOnClickListener {
            binding.chronometer.base = SystemClock.elapsedRealtime() + pauseTime    // 이전 시간부터 스타트
            binding.chronometer.start()
            binding.startButton.isEnabled = false
            binding.stopButton.isEnabled = true
            binding.resetButton.isEnabled = true
            binding.runImage.isVisible = true
            binding.stopImage.isVisible = false
            binding.watchImage.isVisible = false
        binding.stopButton.setOnClickListener {
            pauseTime = binding.chronometer.base - SystemClock.elapsedRealtime()
            binding.chronometer.stop()
            binding.startButton.isEnabled = true
            binding.stopButton.isEnabled = false
            binding.runImage.isVisible = false
            binding.stopImage.isVisible = true
        binding.resetButton.setOnClickListener {
            pauseTime = 0L
            binding.chronometer.base = SystemClock.elapsedRealtime()    // ??
            binding.resetButton.isEnabled = false
            binding.watchImage.isVisible = true
    // 뒤로가기 버튼 이벤트 핸들러
    override fun onKeyDown(keyCode: Int, event: KeyEvent?): Boolean {
        // 뒤로가기 버튼을 눌렀을 때
        if (keyCode == KeyEvent.KEYCODE_BACK) {
            // 뒤로가기 버튼을 처음 눌렀거나 누른 지 3초가 지났을 때 처리 (3초내 한 번 더 누를 시 종료)
            if (System.currentTimeMillis() - initTime > 3000) {
                Toast.makeText(this, "종료하려면 한 번 더 누르세요!!", Toast.LENGTH_SHORT).show()
                initTime = System.currentTimeMillis()
                return true
        return super.onKeyDown(keyCode, event)
build.gradle(Module)
// 안드로이드 스튜디오 4.0 이상
android {
    buildFeatures {
        viewBinding = true
