Kotlin 고급 위젯 - 그 밖의 뷰 컨테이너(View Container) : 프래그먼트(Fragment)
작성자 임베디드코리아 작성일23-09-24 03:51 조회7,313회 댓글0건
    <FrameLayout
        android:id="@+id/frameLayout"
        android:layout_width="0dp"
        android:layout_height="0dp"
        android:layout_marginStart="10dp"
        android:layout_marginEnd="10dp"
        app:layout_constraintBottom_toTopOf="@+id/fragment1_btn"
        app:layout_goneMarginTop="10dp">
    </FrameLayout>
        android:id="@+id/fragment1_btn"
        android:layout_margin="10dp"
        android:text="Go Frag1"
        android:textAllCaps="false"
        app:layout_constraintEnd_toStartOf="@+id/fragment2_btn"
        app:layout_constraintTop_toBottomOf="@+id/frameLayout" />
        android:id="@+id/fragment2_btn"
        android:text="Go Frag2"
        app:layout_constraintStart_toEndOf="@+id/fragment1_btn"
*** <  res/layout 에 fragment_1.xml 과 fragment_2.xml 를  추가한다.  > ************
      fragment_1.xml
<FrameLayout xmlns:android="http://schemas.android.com/apk/res/android"
    tools:context=".Fragment1">
    <!-- TODO: Update blank fragment layout -->
        android:layout_height="126dp"
        android:background="@color/white"
        android:text="여기는\nFragment 1 입니다."
        android:textSize="40sp"
        android:textColor="#3949AB"
</FrameLayout>
      fragment_2.xml
    tools:context=".Fragment2">
        android:text="여기는\nfragment 2 입니다."
        android:textColor="#4AAB39"
        android:background="#F4DE7A"
        app:layout_constraintBottom_toBottomOf="parent" />
    <ImageView
        android:src="@drawable/sun"
</FrameLayout>
    private val binding by lazy { ActivityMainBinding.inflate(layoutInflater) }
        setContentView(binding.root)
        binding.run {  // 1번
            fragment1Btn.setOnClickListener{
                setFragment(Fragment1()) //3번
            fragment2Btn.setOnClickListener {
                setFragment(Fragment2())
    private fun setFragment(frag : Fragment) {  //2번
        supportFragmentManager.commit {
            replace(R.id.frameLayout, frag)
            setReorderingAllowed(true)
            addToBackStack("")
*** <  app/java 에 Fragment1.kt 과 Fragment2.kt 를  추가한다.  > ************
    Fragment1.kt
// TODO: Rename parameter arguments, choose names that match
// the fragment initialization parameters, e.g. ARG_ITEM_NUMBER
private const val ARG_PARAM1 = "param1"
private const val ARG_PARAM2 = "param2"
 * A simple [Fragment] subclass.
 * Use the [Fragment1.newInstance] factory method to
 * create an instance of this fragment.
class Fragment1 : Fragment() {
    // TODO: Rename and change types of parameters
    private var param1: String? = null
    private var param2: String? = null
        arguments?.let {
            param1 = it.getString(ARG_PARAM1)
            param2 = it.getString(ARG_PARAM2)
    override fun onCreateView(
        inflater: LayoutInflater, container: ViewGroup?,
    ): View? {
        // Inflate the layout for this fragment
        return inflater.inflate(R.layout.fragment_1, container, false)
    companion object {
        * Use this factory method to create a new instance of
        * this fragment using the provided parameters.
        * @param param1 Parameter 1.
        * @param param2 Parameter 2.
        * @return A new instance of fragment Fragment1.
        // TODO: Rename and change types and number of parameters
        @JvmStatic
        fun newInstance(param1: String, param2: String) =
            Fragment1().apply {
                arguments = Bundle().apply {
                    putString(ARG_PARAM1, param1)
                    putString(ARG_PARAM2, param2)
    Fragment2.kt
 * Use the [Fragment2.newInstance] factory method to
class Fragment2 : Fragment() {
        arguments?.let {
    ): View? {
        return inflater.inflate(R.layout.fragment_2, container, false)
    companion object {
        * @return A new instance of fragment Fragment2.
        @JvmStatic
            Fragment2().apply {
    build.gradle(Module)
// 안드로이드 스튜디오 4.0 이상
android {
    buildFeatures {
        viewBinding = true
