Kotlin 고급 위젯 - 그 밖의 뷰 컨테이너(View Container) : 슬라이딩드로어(SlidingDrawer)
작성자 임베디드코리아 작성일23-09-24 03:13 조회7,188회 댓글0건
        android:text="여기는 서랍밖입니다" />
    <SlidingDrawer
        android:content="@+id/content"
        android:handle="@+id/handle"
            android:id="@+id/handle"
            android:text="서랍 손잡이" />
        <LinearLayout
            android:id="@+id/content"
            android:background="#00FF00"
            android:gravity="center">
                android:text="여기는 서랍안입니다" />
    </SlidingDrawer>
    android:id="@+id/layout"
    <SlidingDrawer
        android:id="@+id/simpleSlidingDrawer1"
        android:content="@+id/content1"
        android:handle="@+id/handle1"
        android:orientation="horizontal"
        android:rotation="180">
        <!-- Let us define the button -->
            android:id="@id/handle1"
            android:background="#0f0"
            android:rotation="270"
            android:text="Open"
            android:textColor="#fff" />
        <!-- layout for the content of the SlidingDrawer -->
        <LinearLayout
            android:id="@id/content1"
            <!-- Define all your current, Widgets here which
                you want to add in Sliding Drawer Layout -->
            <ListView
                android:id="@+id/simpleListView1"
                android:layout_height="fill_parent" />
    </SlidingDrawer>
      list_item.xml
    <!-- TextView for the list item -->
        android:id="@+id/name1"
        android:padding="10dp"
        android:textColor="#0022FF" />
    var nameArray = arrayOf("Bitcoin", "Ethereum", "Litecoin", "IOTA", "Libra", "Monero",
        "EOS", "NEO", "ATOM", "Tether", "XRP", "Bitcoin Cash", "Binance Coin",
        "REN", "Bitcoin SV", "USD Coin", "Stellar", "Tezos", "Dash", "Zcash")
        // initiate the SlidingDrawer
        val simpleSlidingDrawer1 = findViewById<SlidingDrawer>(R.id.simpleSlidingDrawer1)
        // initiate a Button which is used for handling the content of SlidingDrawer
        // We can able to have open and close methods for this handleButton
        val handleButton = findViewById<Button>(R.id.handle1)
        // initiate the ListView that is used for content of SlidingDrawer adapter
        // for the list view. As all are text, it is defined as ArrayAdapter<String>
        // Your cryptocurrency items are going to be displayed via this view using
        // below cryptocurrency ArrayAdapter
        val simpleListView1 = findViewById<ListView>(R.id.simpleListView1)
        // Below syntax is for defining ArrayAdapter
        val cryptocurrencyArrayAdapter = ArrayAdapter(applicationContext, R.layout.list_item, R.id.name1, nameArray)
        // set an adapter to fill the data in the ListView
        simpleListView1.adapter = cryptocurrencyArrayAdapter
        // implement setOnDrawerOpenListener event, name itself suggests that
        // we need to write code for drawer opening
        simpleSlidingDrawer1.setOnDrawerOpenListener {
            // When drawer is opened, we may need to indicate user that close option is available,
            // so just setting text to close. But required functionality can be done here
            handleButton.text = "Close"
        // implement setOnDrawerCloseListener event, name itself suggests we need to write close events
        simpleSlidingDrawer1.setOnDrawerCloseListener {
            // if close is done, we should have the option to open. according
            // to the requirement, carry out necessary steps for close
            handleButton.text = "Open"
uild.gradle (app) 에 라이브러리 추가하기
DrawerLayout은 Support Library v4에 포함된 클래스이므로 build.gradle (Module: app)에 Support Library를 추가한다.
android {
  dependencies {
    implementation 'androidx.legacy:legacy-support-v4:1.0.0' // DrawerLayout
    implementation 'com.google.android.material:material:1.0.0' // NavigationView
