Kotlin 고급 위젯 - 기 타: 시크바(SeekBar)
작성자 임베디드코리아 작성일23-09-24 01:44 조회6,517회 댓글0건
    <SeekBar
    android:id="@+id/seekBar"
    android:layout_marginStart="60dp"
    android:layout_marginEnd="60dp"
    android:max="50"
    android:progress="20"
    app:layout_constraintHorizontal_bias="1.0"
        android:id="@+id/textView"
        android:layout_marginBottom="16dp"
        android:text="기본 값은 20입니다"
        app:layout_constraintBottom_toTopOf="@+id/seekBar"
    private lateinit var textView: TextView
    private lateinit var seekBar: SeekBar
        /*    텍스트뷰 초기화    */
        textView = findViewById(R.id.textView)
        /*    시크바 초기화    */
        seekBar = findViewById(R.id.seekBar)
        seekBar.setOnSeekBarChangeListener(object : SeekBar.OnSeekBarChangeListener {
            override fun onProgressChanged(seekBar: SeekBar?, progress: Int, fromUser: Boolean) {
                textView.text = progress.toString()
            override fun onStartTrackingTouch(seekBar: SeekBar?) {
            override fun onStopTrackingTouch(seekBar: SeekBar?) {
