Kotlin 고급 위젯 - 날짜와 시간 관련 위젯 : 데이트피커(DatePicker) Dialog
작성자 임베디드코리아 작성일23-09-24 00:50 조회6,897회 댓글0건
        android:id="@+id/start_text"
        style="bold"
        android:layout_width="60dp"
        android:gravity="center"
        android:text="시 작"
        android:textSize="20dp"
        app:layout_constraintEnd_toStartOf="@+id/start_date_text"
        app:layout_constraintVertical_bias="0.147" />
        android:id="@+id/start_date_text"
        android:layout_width="200dp"
        android:layout_height="40dp"
        android:layout_marginStart="60dp"
        android:gravity="center_vertical"
        android:paddingHorizontal="5dp"
        app:layout_constraintStart_toEndOf="@+id/start_text"
        app:layout_constraintVertical_bias="0.137" />
    <ImageView
        android:id="@+id/start_date_btn"
        android:layout_width="349dp"
        android:layout_height="414dp"
        tools:layout_editor_absoluteX="16dp"
        tools:layout_editor_absoluteY="236dp" />
    //Calendar
    private var calendar = Calendar.getInstance()
    private var year = calendar.get(Calendar.YEAR)
    private var month = calendar.get(Calendar.MONTH)
    private var day = calendar.get(Calendar.DAY_OF_MONTH)
        var start_date_BTN: ImageView = findViewById(R.id.start_date_btn)
        var start_date_TEXT: TextView = findViewById(R.id.start_date_text)
        start_date_BTN.setOnClickListener {
            val datePickerDialog = DatePickerDialog(this, { _, year, month, day ->
                start_date_TEXT.text =
                    year.toString() + "/" + (month + 1).toString() + "/" + day.toString()
            }, year, month, day)
            datePickerDialog.show()
