Kotlin 고급 위젯 - 날짜와 시간 관련 위젯 : 크로노미터(Chronometer)
작성일 23-09-24 00:03
조회6,891회
<LinearLayout
<Chronometer
android:id="@+id/exChronometer"
android:format="시간 측정 : %s"
android:gravity="center"
android:textSize="30dp" />
android:id="@+id/startBT"
android:text="START"
android:layout_marginLeft="20dp"
android:id="@+id/stopBT"
android:text="STOP"
android:id="@+id/restartBT"
android:text="RESTART"
android:id="@+id/setBT"
android:text="SET FORMAT"
android:id="@+id/clearBT"
android:text="CLEAR FORMAT"
private lateinit var simpleChronometer: Chronometer
private lateinit var start: Button
private lateinit var stop: Button
private lateinit var restart: Button
private lateinit var setFormat: Button
private lateinit var clearFormat: Button
var pauseTime=0L
simpleChronometer = findViewById(R.id.exChronometer)
start = findViewById(R.id.startBT)
stop = findViewById(R.id.stopBT)
restart= findViewById(R.id.restartBT)
setFormat = findViewById(R.id.setBT)
clearFormat = findViewById(R.id.clearBT)
start.setOnClickListener {
simpleChronometer.start()
stop.setOnClickListener {
pauseTime = simpleChronometer.base - SystemClock.elapsedRealtime()
simpleChronometer.stop()
restart.setOnClickListener {
simpleChronometer.base = SystemClock.elapsedRealtime()+pauseTime
setFormat.setOnClickListener {
simpleChronometer.setFormat("새로운 형식 : %s")
clearFormat.setOnClickListener {
simpleChronometer.setFormat("")
