작성일 23-09-12 00:26
조회6,982회
<LinearLayout
android:orientation="horizontal">
android:id="@+id/TestTV"
android:text="Android Kotlin"
android:textSize="20sp"
android:textStyle="bold"
android:id="@+id/TestBT"
android:text="Button"
android:layout_marginLeft="20dp"
android:id="@+id/TestET"
android:ems="10"
android:inputType="text"
android:text="Name"
<LinearLayout
android:id="@+id/et01"
android:ems="10"
android:background="#C1BDBD"
android:layout_gravity="center" />
android:id="@+id/bt01"
android:text="Click"
android:id="@+id/tv01"
android:layout_width="300dp"
android:background="#8CBDA5"
<LinearLayout
android:id="@+id/etINdata01"
android:layout_width="150dp"
android:ems="10"
android:inputType="number"
android:background="#C3B392"
android:layout_marginRight="20dp"
android:layout_marginTop="100dp" />
android:id="@+id/etINdata02"
android:ems="10"
<LinearLayout
android:id="@+id/bt02"
android:text="실행"
android:id="@+id/tv02"
android:text="결과"
android:layout_marginTop="10dp" />
private lateinit var testET: EditText
private lateinit var editText01: EditText
private lateinit var INdata01: EditText
private lateinit var INdata02: EditText
private lateinit var testButton: Button
private lateinit var button01: Button
private lateinit var button02: Button
private lateinit var testTV: TextView
private lateinit var textView01: TextView
private lateinit var textView02: TextView
var nCount : Int = 0
var etCount : Int = 0
/* 에디트텍스트 초기화 */
testET= findViewById(R.id.TestET)
editText01 = findViewById(R.id.et01)
//editText01= findViewById<EditText>(R.id.bt01);
//var editText01: EditText = findViewById(R.id.bt01);
INdata01= findViewById(R.id.etINdata01)
INdata02 = findViewById(R.id.etINdata02)
//editText02= findViewById<EditText>(R.id.bt02);
//var editText02 : EditText = findViewById(R.id.bt02);
/* 버튼 초기화 */
testButton = findViewById(R.id.TestBT)
button01 = findViewById(R.id.bt01)
//button01= findViewById<Button>(R.id.bt01);
//var button01 : Button = findViewById(R.id.bt01);
button02 = findViewById(R.id.bt02)
//button02= findViewById<Button>(R.id.bt02);
//var button02 : Button = findViewById(R.id.bt02);
/* 텍스트뷰 초기화 */
testTV = findViewById(R.id.TestTV)
textView01 = findViewById(R.id.tv01)
//textView01 = findViewById<TextView>(R.id.textView);
//var textView01 : TextView = findViewById(R.id.tv01);
textView02 = findViewById(R.id.tv02)
//textView02 = findViewById<TextView>(R.id.textView);
//var textView02 : TextView = findViewById(R.id.tv01);
testTV.setOnClickListener {
testTV.apply {
setBackgroundColor(Color.RED)
text = "Clicked!! ${nCount++}"
setTextColor(Color.WHITE)
setTextSize(28.0F)
testButton.setOnClickListener {
testButton.apply {
setBackgroundColor(Color.GREEN)
setTextColor(Color.BLUE)
text = "Finish"
setTextSize(20.0F)
testET.setOnClickListener {
testET.apply {
setBackgroundColor(Color.GRAY)
setTextSize(20.0F)
testTV.text = text.toString()
button01.setOnClickListener {
textView01.text = editText01.text.toString();
textView02 .setOnClickListener {
// setOnClickListener는 파라메터로 클릭한 Control인 View 객체를 넘겨준다.
// 이름을 따로 정의하지 않으면, it으로 되어 있다.
// it을 TextView로 캐스팅하고 사용할 수 있다.
val textView02 = it as TextView
textView02.text = Html.fromHtml(
"<h1>Hi</h1>HTML<p style=\"color:red;\">Red</idv>")
INdata01.setOnClickListener {
INdata01.setText(null)
INdata02.setOnClickListener {
INdata02.setText(null)
button02.setOnClickListener {
button02.apply {
var aData: Int=0
var bData: Int=0
var cData: Int=0
var Astr: String = INdata01.text.toString()
var Bstr: String = INdata02.text.toString()
aData = Astr.toInt()
bData = Bstr.toInt()
cData = aData + bData
textView02.text = cData.toString()
setTextSize(20.0F)
