Kotlin 클래스
작성자 임베디드코리아 작성일23-08-27 20:46 조회5,810회 댓글0건
    MainActivity..kt
    private lateinit var BTN01: Button
    private lateinit var BTN02: Button
    private lateinit var BTN03: Button
    private lateinit var TV: TextView
        BTN01= findViewById(R.id.Button01)
        BTN02= findViewById(R.id.Button02)
        BTN03= findViewById(R.id.Button03)
        TV= findViewById(R.id.TextTV)
        val smartTvDevice = SmartDevice("Android Tv","Entertainment")
        //smartTvDevice.turnOn()
        //smartTvDevice.turnOff()
        BTN01.setOnClickListener  {
            TV.setText("Device name is: ${smartTvDevice.name}")
            Toast.makeText(applicationContext, "Device name is: ${smartTvDevice.name}", Toast.LENGTH_LONG).show()
            println("Device name is: ${smartTvDevice.name}")
        BTN02.setOnClickListener  {
        BTN03.setOnClickListener  {
class SmartDevice(val name: String, val category: String): AppCompatActivity() {
    var deviceStatus = "online"
    fun turnOn(){
        //Toast.makeText(this@SmartDevice,"Smart device is turned on.", Toast.LENGTH_LONG).show()
        println("Smart device is turned on.")
    fun turnOff(){
        //Toast.makeText(this@SmartDevice, "Smart device is turned on.", Toast.LENGTH_LONG).show()
        println("Smart device is turned off.")
    <LinearLayout
            android:id="@+id/TextTV"
            android:text="Android Kotlin"
            android:textSize="20sp"
            android:textStyle="bold"
            android:id="@+id/Button01"
            android:text="Button"
            android:layout_marginLeft="20dp"
            android:id="@+id/Button02"
            android:id="@+id/Button03"
