작성일23-08-27 20:38
조회7,010회
MainActivity..kt
private lateinit var text1: TextView
//텍스트뷰 초기화
text1 = findViewById(R.id.textView)
//text1 = findViewById<TextView>(R.id.textView);
// print Function
printSum(5104, 1005)
printString("Embedded Korea")
var tot = sumFun(10, 20)
text1.append("return 값 \n")
text1.append("sum + 100 = $tot \n")
// 단일 표현식 함수
text1.append("\n단일 표현식 함수 \n")
var s1=sum(30,60)
text1.append("return 값 : $s1 \n")
var s2=sum(30,220)
text1.append("return 값 : $s2 \n")
fun printSum(a: Int, b: Int): Unit {
text1.append("------- printSum -------\n")
text1.append("sum of $a and $b is ${a + b}\n")
text1.append("\n")
fun printString(s: String){
text1.append("--- printString ---Unit 생략---\n")
text1.append("$s\n")
text1.append("\n")
fun sumFun(a: Int, b: Int): Int {
var sum : Int
sum = a + b
text1.append("** 함수 내에서 출력 ** \n")
text1.append("$a + $b = $sum \n")
return sum+100
fun sum(a: Int, b: Int): Int {
return a + b
fun sum2(a: Int, b: Int) = a + b
android:id="@+id/textView"
android:textSize="30sp"
android:textStyle="bold"
