작성일23-08-22 00:04
조회6,941회
android:id="@+id/textView"
android:textSize="30sp"
android:textStyle="bold"/>
var textView : TextView = findViewById(R.id.textView);
//문자
var mString : String = "EmbeddedKorea";
val isChar: Char='K';
//정수
var mInt : Int = -300;
var mLong : Long = -3;
// unsigned 정수
var mUInt : UInt = 123u;
var mULong : ULong = 3u;
//실수
var mDouble : Double = 2.3;
var mFloat : Float = 4.0f;
//논리형
val isReal: Boolean;
isReal=false;
//Byte
val isByte: Byte;
isByte=-123;
//UByte
val isUByte: UByte;
isUByte=123u;
//Show
val isShort: Short;
isShort=-456;
//Show
val isUShort: UShort;
isUShort=456u;
//Any
val isAnyInt1: Any?;
val isAnyInt2: Any;
isAnyInt1=10;
isAnyInt2=isAnyInt1;
val isAnyString: Any;
isAnyString="kilsung";
//텍스트뷰에 담기
textView.append("String: " + mString + "\n");
textView.append("Char: " + isChar+ "\n");
textView.append("Int: " + mInt.toString() + "\n");
textView.append("UInt: " + mUInt.toString() + "\n");
textView.append("Long: " + mLong.toString() + "\n");
textView.append("ULong: " + mULong.toString() + "\n");
textView.append("Double: " + mDouble.toString() + "\n");
textView.append("Float: " + mFloat.toString() + "\n");
textView.append("Boolean: " + isReal.toString() + "\n");
textView.append("Byte: " + isByte.toString() + "\n");
textView.append("UByte: " + isUByte.toString() + "\n");
textView.append("Short: " + isShort.toString() + "\n");
textView.append("UShort: " + isUShort.toString() + "\n");
textView.append("Any Int1: " + isAnyInt1.toString() + "\n");
textView.append("Any Int2: " + isAnyInt2.toString() + "\n");
textView.append("Any String: " + isAnyString.toString() + "\n");
